high, surging idle
high, surging idle
alright so ive got a fun one guys.
at first i had an idle surge so i of course replaced the , (code p0505) then it went away for a bit and came back at random, but would idle high (around 1500-1700)
replaced ( it tested bad 2 ohms).
it was running at 110 today then the second i snap accelerated it started surging
i have a little bit of what seems to be valve noise, not to worried about it, has 198k on it, no idea about , distributor timing is most likely off due to my having to do the seal on it and not getting a chance to set it back up properly, not the biggest deal.
im at a loss.
no there are no vaccum leaks i smoke tested the car.
im at a loss.
Re: high, surging idle
thats what im thinking, i mean its a denso the same i pulled out of the car in the first place, but its also the 2nd one i put in the car because i figured the iac i bought the first time might be bad
get your ignition timing straight man....probably fix it right there...and since you replaced the IACV and opened up the coolant lines...did you happen to burp it after...even a little air will cause idle issues...
brian0128
Feb 17, 2010 12:26 PM
boostnm3
Dec 28, 2009 04:02 PM
LVEM2
Feb 11, 2008 05:34 PM
chadzeilenga
Mar 25, 2007 02:26 PM
