1997 Civic Hatch DX - Surging Idle
Old Mar 19, 2007
chadzeilenga's Avatar
chadzeilenga is an unknown quantity at this point
I've went thru and seached the forums on this topic, but haven't been able to find a cure for my problem. I've got a 1997 Civic Hatch DX that I just replaced the stock 1.6L engine with another stock 1.6L engine. After I got everything done I fired it up and it started and seemed to run really smooth. Once the engine had warmed up it began surging up & down at idle. It would go from ~800 to 1500 RPM over and over again. When I gave it some gas it smoothed out and the problem went away. I don't notice it when I am driving, just in park while the car is idling??? Does anyone have any ideas? I pulled the IAC sensor off and let it run without it and it seemed to steady for a while, but then the surging came back.
Thanks,
Chad
Old Mar 20, 2007
sql_civic's Avatar
Re: 1997 Civic Hatch DX - Surging Idle
Did you mix up the IACV and TPS sensor plugs? I think they both have the same plugs that are commonly switched and that can cause this problem.
Old Mar 21, 2007
Thanks, I was confused about those plugs at first, but the IACV plug has longer wires so I figured it went to the IACV instead of the TPS. I spent quite a while last night bleeding the coolant system out and could not get it to idle right even with the heater on full blast. I pulled it out of the garage and onto the sloped driveway and that seemed to get the bubbles out of where they weren't supposed to be.
Know of where I can find the rubber piece that goes inside my window track? Mine is missing and the window doesn't go all the way up without it.
Chad
Old Mar 21, 2007
HondCivc91's Avatar
HondCivc91 is an unknown quantity at this point
i dunno i'd say spray some cleaner in the throttle body but being that it was right after the engine swap it's probably something more complex.
Old Mar 25, 2007
I've got the idle surge solved. I began by bleeding the system of air with the heater on full blast but it still seemed to do it so I let the car idle on an incline facing both directions and that was enough to get the air out of the system.
Thanks,
usajags84
15
Aug 19, 2015 03:12 AM
Rinzlor
Apr 24, 2015 10:33 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
chirp the 1-2
Apr 19, 2015 02:19 PM
