2000 Civic Auto trans slip
Just bought a car for my sister, 2000 civic EX w/ 146k miles. The RPMs will jump up ~500 when it shifts from 1st to 2nd or 2nd to 3rd. No check engine light or slipping in other gears, trans fluid is at the correct level and clean. Cursory google searches say its the shift solenoid. I would love to know if this is the likely issue before I drop the 150$ on a new one. Thanks.
Re: 2000 Civic Auto trans slip
Remove and clean the shift solenoids and gasket screen with brake cleaner spray.
Do a 3x3 ATF drain and fill. Okay to use Valvoline Maxlife full synthetic ATF. If you don't know when the last ATF change was then do one asap regardless of current dye color.
shiguiy
Dec 28, 2015 11:52 PM
scguy64
Dec 15, 2013 05:13 PM
Soarer
Nov 22, 2010 11:52 AM
