Difficulty shifting
Old Jul 18, 2016
leeant's Avatar
leeant is an unknown quantity at this point
Difficulty shifting
Hello guys,
I am having difficulties with my 97 Civic EX coupe. When i'm shifting gears there is difficulty putting it into the gear and this happens for each one and is probably worst for reverse.
This started happening after i changed from the stock shifter to a used Skunk2 short shifter. after a couple months of usage i noticed that the shifts were getting harder and harder. When in neutral and in gear the shifter wobbles left and right a lot. This did not happen with the stock shifter.
After thinking that it may have been low on Transmission fluid i changed the fluid out with Honda MTF which did not work as it is still difficult to put the car into gear.
I also noticed that there is some transmission fluid leakage from the shift linkage. I checked for any leaks from the clutch master cylinder and slave cylinder but didn't find any.
Please help me out here. Much appreciated.
Old Jul 19, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Difficulty shifting
Go back to stock if you can and see if the issue goes away.
If not there may be an issue with a synchro or bearing.
Kennykenny
Electrical
Oct 31, 2015 02:36 PM
Hani4g
Oct 31, 2015 02:09 PM
Lopezsoul
Oct 29, 2015 08:30 PM
cboyd
Oct 29, 2015 06:43 PM
Othelius
Oct 23, 2015 07:25 PM
