Timing belt
Old May 21, 2016
fvckbg's Avatar
fvckbg is an unknown quantity at this point
Timing belt
I finished changing a cylinder head gasket and I put everything back together, but my only problem is the timing belt. I marked where its supposed to go but the force is really strong and I can't get it to slide back on. Any ideas?
Old May 21, 2016
Re: Timing belt
Loosen tensioner, move pulleys as needed (dont bend valves) start the timimg belt install from scratch
Use the timing marks honda put on the engine
Old May 21, 2016
TS2008's Avatar
TS2008 is an unknown quantity at this point
Re: Timing belt
Not sure what's your problem with the tb, but what I did was I push the tensioner arm and than lock the tensioner by tightening the bolt. I then install the timing belt and I loose the bolt and let the tensioner spring do his job. For my case, My tensioner spring was too weak and I have to push the tensioner arm to give the rear side of the timing belt the appropriate tension.
cukaracha
Mar 16, 2016 07:38 AM
manda_panda
Mar 14, 2016 09:10 PM
illanrob
Mar 12, 2016 08:06 AM
help.me
Mar 2, 2016 07:07 PM
Mv7fd
15
Feb 28, 2016 07:07 AM
