back firing
Old Mar 14, 2016
manda_panda's Avatar
manda_panda is an unknown quantity at this point
back firing
Changed the plugs and wires after started having problems with ruff idle now since everything is changed im getting back fire really bad and car isn't running rite. What do i do?
Old Mar 14, 2016
Re: back firing
Verify you didn't get plug wires in the wrong places around the dist cap.
Gotta follow firing order not numerical order
Old Mar 14, 2016
Re: back firing
The order was correct. It was exactly the same as it had always been. I made sure. Checked to make sure they were pluged in all the way everything. It didn happen tho til the tps was correctly installed and calibrated
Old Mar 14, 2016
Re: back firing
Exactly what procedure was done and what spec was used to complete this?
Was it having problems before you installed the ignition parts?
EDIT: What year/model/engine is your car?
Old Mar 14, 2016
Re: back firing
Replaced plugs and wires. Have checked the firing order and made sure everything was seated properly. Then replaced tps. Calibrated it to .5v at idle and 4.5v at wot. Was doing fine then hit 5000rpms it backfired. Now it stalls rite after start and backfires the whole time.
Old Mar 14, 2016
Re: back firing
Also its a b20z2 in a 00 civic si
Old Mar 14, 2016
Re: back firing
Thread moved to 6th gen
CRV engine?
5000 rpm..........Double checked cam timing? Maybe one cam jumped time?
Old Mar 14, 2016
Re: back firing
It all looks correct. Thinking it may be the crank positioning sensor. Found a broken connector by the bottom pully but cant see what it goes 2
Old Mar 14, 2016
Re: back firing
NOt sure how your engine swap was wired up....
Crank position sensor (CKP) is inside the distributor....The sensor on the front of the crank was used for misfire detection (crankshaft fluctuation sensor or CKF sensor) and I don't think it affects running.
Check engine light on? Codes?
Recheck inside dist cap--rotor came loose maybe? Moisture in the cap? Arc trails? Cracked cap?
You say it backfires and dies at idle....Does it run above idle?
kinglenoidas
Dec 19, 2015 08:21 AM
mac25
General 7th Gen
Dec 16, 2015 12:46 AM
steve6
Nov 22, 2015 08:18 PM
rojasj
Nov 15, 2015 06:53 PM
R Steele
Oct 22, 2015 05:09 AM
