Smoke coming from trunk of car
Old 05-16-2016
fvckbg's Avatar
fvckbg is an unknown quantity at this point
So I have a 98 civic ex and I've had this problem since yesterday. Basically whenever I play music, after awhile I smell this weird smell coming from the back of my car. I know it's coming from my system cause when I don't play music I don't ever smell anything. I can't really describe the smell, but it's like a burning smell. So I went and popped the trunk open and tried tracing where the smell is coming from. I found out the smell is strongest where the ground wire is connected to the car. I checked all the wires and none of them are loose cause I have them connected to the spade connectors. The ground wire is fine so I really don't know where this smell is coming from. Any ideas?
Old 05-16-2016
Prelude Owner
GolNat's Avatar
Re: Smoke coming from trunk of car
Is it grounded well? Did this just start happening or has the system been in the car for a while?
I wouldn't use your radio until it is fixed. Did you check speaker wires? The power wire that goes to the battery?
Old 05-16-2016
fvckbg's Avatar
yea it's grounded pretty good and I've had the system for awhile too. Everything was fine until yesterday. Speaker wires are good as well. Didn't check the power wire though.
Old 05-16-2016
Use your fingers and FEEL the wire/ends/crimps/connection areas (after you start smelling the stink of course).
Points of high resistance and poor connections will get HOT, these need to be corrected.
Old 05-16-2016
Stock 99's Avatar
If somethings getting hot enough to smell it'll be super hot. Like ezone said just touch everything when you start to smell it. Do you have a fuse at the battery from your power lead to the amp? If not the whole length of that wire could be suspect as well.
Old 05-16-2016
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Do you have 2 or 3 way speakers in the rear? If so, sounds like the capacitor in the crossover is going out.
TiggerDX
11-18-2015 12:49 AM
EuroCivic
12-07-2001 12:56 PM
AzNmiKex215
11-29-2001 08:02 PM
antidote11
11-27-2001 10:46 PM
Quick Reply: Smoke coming from trunk of car
