1996 Civic EX broken wires at door hinge area
Old May 15, 2016
Bauxite's Avatar
Bauxite is an unknown quantity at this point
1996 Civic EX coupe has inop windows due to broken wires at door hinge area. Too tight to clearly see what the connectors look like. Anyone have a picture or detailed description of what is there so I can avoid breaking old plastic? Thanks.
Old May 18, 2016
mac25's Avatar
Dr Krieger of Modification
Re: 1996 Civic EX broken wires at door hinge area
Take off door skins, use a multi meter to find which wire is broken, then solder in your own wire.
I did the same on my 2002, it took about 30min.
Old May 18, 2016
No need to remove the door panel.
The harness unplugs from the outside of the door in the hinge area.
It is part of the cars floor wiring harness. You can poke the end through the pillar so you can work with it on the floor of the car much easier than trying to squeeze your body into the front edge of the door.
No, I don't have pics of those connectors handy...but google sure does
https://www.google.com/search?q=96+civic+door+connector&newwindow=1&safe= off&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiEkffBrOX MAhVM7CYKHTOpD3gQ_AUICCgC&biw=1344&bih=769
OptimisticWay
Jan 3, 2016 07:54 AM
M00n3at3r
Nov 14, 2015 03:12 PM
Jason16
Oct 27, 2015 09:12 PM
AzNmiKex215
Nov 29, 2001 08:02 PM
SneakerPimp
Nov 28, 2001 10:45 PM
