Bad 02 sensor
Old Apr 20, 2016
hickz07's Avatar
hickz07 is an unknown quantity at this point
Bad 02 sensor
OK to start off I'm not the smartest guy when it comes to cars but I'm learning. So I've read that this year of civic should only have 2 sensors but mine has 3 most likely because my civic has an after market exhaust system. The one on the manifold, after the manifold and on the cat. The one after the manifold is bad and I want to buy a new one to replace it but I am not sure which to buy.
Old Apr 20, 2016
Poopies's Avatar
Super Moderator
Re: Bad 02 sensor
Well for starters what year and trim level do you have?
Old Apr 21, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Bad 02 sensor
If you can answer Poopies and post a picture of the sensor, we can point you in the right direction.
Old Apr 21, 2016
hickz07's Avatar
Re: Bad 02 sensor
my bad it's a 99 ex.
Old Apr 21, 2016
hickz07's Avatar
Re: Bad 02 sensor
I'm at work right now but I'll get that picture as soon as possible
Old Apr 21, 2016
Poopies's Avatar
Super Moderator
Re: Bad 02 sensor
You're looking at part 41 here:
http://estore.honda.com/honda/parts/...=B++02&dl=#041
I assumed you had a 4 door automatic so you can change that in the top menu if you'd like. It should all be the same though. Now you might notice that the part goes for over $300.00. I'd recommend searching the part number on the Google and using another source. Just my $.02
BTW the Honda estore is not showing a sensor on the manifold. Now I'm intrigued!
Old Apr 21, 2016
Re: Bad 02 sensor
Mechanical problem related, not a bolt-on performance item, so moving to correct section.
Old Apr 22, 2016
Poopies's Avatar
Super Moderator
Re: Bad 02 sensor
Oh snap! I missed that!
Old Apr 22, 2016
Wankenstein's Avatar
Re: Bad 02 sensor
A stock EX and SI models have a cat-back design: cat convertor is located farther down the exhaust as compared to other base models where the CC is welded to the manifold. Do you know if you a manifold or did a prior owner install after-market headers? In the pic below it shows headers (chrome) on the left and the stock manifold on the right. Either setup you should only have one primary sensor (pre-cat) and one secondary sensor (post-cat). A stock wiring harness would only have connections for these two sensors.
The one that you said is bad is the primary (upstream) sensor should be this one:
Amazon.com: Denso 234-4733 Oxygen Sensor: Automotive Amazon.com: Denso 234-4733 Oxygen Sensor: Automotive
How do you know it's not working? related CEL?
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
MassCivic
Nov 23, 2015 06:22 PM
05Ep3k20si
Electrical
Nov 6, 2015 04:26 PM
Hani4g
Oct 31, 2015 02:09 PM
