97 Honda cooling fan
Old Mar 11, 2016
Mikew94's Avatar
Mikew94 is an unknown quantity at this point
Fan works relay works but when car is running fan never comes on
Old Mar 11, 2016
Re: 97 Honda cooling fan
How do you know the fan relay works? How did you check it?
What else has been tested?
Is it overheating?
The way they are set up, it can take a long dang time before the fan needs to run.
Wait a sec...A moderator removed the other post with more info
My cooling fan is working but it won't come on when my engine is hot the relay works the fan itself works but somethings not right help please
Locate the temp switch for the fan on the thermostat housing, unplug it. Use a bent paper clip to jump the terminals in the harness, see if the fan turns on.
Old Mar 11, 2016
Mikew94's Avatar
Is it overheating?
Yeah I did that it's not over heating it works I bought s new switch and the fan works relay works but when my car is running and they are connected it doesn't work at all
Old Mar 11, 2016
The fan is not supposed to run all the time. It's only supposed to run when needed.
TranTheDoctor
Apr 6, 2016 08:56 AM
1996
Feb 12, 2016 11:41 PM
Jessie711
Feb 12, 2016 02:21 PM
Joelship
Feb 11, 2016 09:23 PM
