Car Idles for 30 Seconds and Dies
Old Feb 12, 2016
1996's Avatar
1996 is an unknown quantity at this point
I've had this automatic 1996 LX for almost a year and it ran perfectly until a month or two ago when it died at a stop light. Realized there was no compression so replaced the piston rings but when that was finally done I found that the distributor wasn't working so replaced that as well. Now it will start up perfectly and idle for about 30 seconds until the tachometer just suddenly drops to nothing and the engine bogs and shakes for a moment, then dies. Thought it had something to do with the crank position sensor but replaced that and still having the problem. Anyone know what might be going on?
Old Feb 12, 2016
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Car Idles for 30 Seconds and Dies
I assume the timing belt is OK and correct and not the original problem of it stopping and bending the valves killing the compression? Does sound like it thinks the valve timing is wrong and turning off the motor. Just keeping your post alive till the real experts come on. Does your car have a crank position sensor at the bottom on the crank and a cam position sensor up to on the cam belt large drive cog? If you put it back one tooth off it will do what you say. It should throw a code.
Old Feb 12, 2016
Aftermarket reman distributors are just crap. Try another one.
68camerors
Sep 24, 2015 06:18 PM
curaze
Sep 22, 2015 08:27 AM
conspiracy90
Jan 19, 2002 08:37 PM
conspiracy90
Jan 19, 2002 03:21 AM
