george mitchell
Old Jan 25, 2016
george mitchell's Avatar
george mitchell is an unknown quantity at this point
Smile george mitchell
I have just replaced my rear drum brakes on my Honda civic 2000. I have adjusted the star-wheel adjuster all the way in . I am having problems getting my brake drums to go back on the new shoes ? could the parking brake adjustment have anything to do with this ? I have removed some brake fluid from the master cylinder and the cover is off .any suggestions would be appreciated .thank you .gm
Old Jan 25, 2016
Re: george mitchell
Make sure wheel cylinder pistons are not stuck, both need to be able to move
handbrake must be completely released
ALL parts must be correctly assembled. (This is why you should only do one side at a time, so you have a correctly assembled set to compare with)
sometimes you have to manipulate the shoes up and down to fit inside the drum, if one or the other is just a little high or low, the drum won't go on.
Once in a while, the aftermarket can really shoot you in the foot....
compare sizes with the old shoes, maybe they are too big.
Old Jan 26, 2016
Smile Re: george mitchell
Have done all you suggested . Was a mechanic for a lot of years and have not had a problem with shoes except on my civic 2000 .rear drum brakes .may just have to sand dow edges of shoes to get 'em to fit . Thanks for your help ,i've just never run into this except on my civic .i appreciate your time and recomendations .should have just gone "oe" but trying to save a buck ,when will i ever learn .lol
Old Jan 26, 2016
Re: george mitchell
Did you get the long fork on the self adjuster flipped upside down? (IDK if it's possible, just guessing)
The cutout where it slips into the handbrake lever isn't equal.
sdraza1
Apr 6, 2021 08:51 AM
WWJD
Sep 23, 2015 12:56 PM
naokigoffi
Aug 30, 2015 06:19 PM
