ABS light not on, but codes stored.
Old Nov 10, 2015
oceanbreeze's Avatar
oceanbreeze is an unknown quantity at this point
96 Civic EX, auto, D16Y8 engine.
To be clear, during normal vehicle operation (i.e., SCS unshorted) the ABS light does NOT come on. When I turn on the ignition the ABS light comes on briefly like all other dash lights.
I was tracking down an intermittent CEL (I have another thread on that), and to my surprise, when I shorted the SCS, the ABS light flashes several codes:
12, 16, 18, 54, 61
I tried resetting them by following the procedure in the manual (scs and brake pedal sequence) but it doesn't erase these codes. I also tried an alternate method (20 x ignition key on/off) and that didn't do anything either.
Everything I have seen in the service manuals about this talk about troubleshooting codes only when the ABS light is set.
Is this something to be worried about?
What do these codes mean when the ABS is not set?
for reference:
http://honda-tech.com/honda-civic-de...lists-1901557/
Old Nov 10, 2015
Re: ABS light not on, but codes stored.
(Assuming the ABS system does work correctly)
If the warning light is not on while driving, don't worry about it... there is not a current fault.
The codes are stored in memory (history codes) and probably have been there for a long time.
IDK if there is a way to manually erase them without a capable scanner, I've never had to find out LOL.
It would be nice to erase the codes, so in the event of a future problem you won't have to sift through all the extra codes that may throw you off track.
11-18 wheel speed sensors
54 ABS main relay
61 ignition voltage
Old Nov 12, 2015
I was able to clear the stored codes by trying the scs and brake pedal sequence again (its from the factory service manual but search for it here). For anyone else who might be trying to erase ABS codes, the procedure requires brake pedal down and up but pay attention to the number of seconds as well as confirming the indicator state.
old97civic
Jun 28, 2015 10:55 AM
bluedoggy1
Jun 20, 2015 11:25 PM
EK_Eddy
Jun 6, 2015 07:31 PM
Tim1959
Jun 3, 2015 08:15 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
