96 Ex auto, sluggish/no acceleration
Old Sep 3, 2015
dantheman42's Avatar
dantheman42 is an unknown quantity at this point
My 96 ex will not get up to speed quickly at all. From a stop i need to almost redline to maintain a Normal acceleration. Hills are laughably bad. No *****. After getting up to 45 mph i can get off the gas a bit. But passing people is sad. Seems to only have issues under 3000rpm. Shifting fine. My exhaust manifold, cat converter, o2 sensors (up and downstream) have all been replaced. Also plugs,wires, distributer cap. Exhaust still leaks slightly near manifold. I can hear it "rattling" due to leak. No CEL. was told my transmission is 100% good. And that my downstream o2 sensor is "flatlining"
Can an o2 sensor fail without a cel? And can that alone be the cause of my civics castration? Is it JUST an o2 or wiring? Best way to test? Other possible causes? Was told by a different shop my tranny fluid was burnt. Does that mean my tranny could be a part? Also master cylinder is going bad ( sometimes sinks sometimes doesn't) locks on one side don't work, oil leaks blah blah. So is this even worth doing? 210 miles on her.
Old Sep 3, 2015
Re: 96 Ex auto, sluggish/no acceleration
No *****.
Camshaft and ignition timing checks?
Yes
Probably not, but you can't say for sure until you find the true cause.
Could be a cause, or it could just be a symptom.
Could be doing exactly what it is supposed to do.
Best way to test?
Disconnect and drive, see if symptom improves
EDIT: Not necessarily the best way, but it's something.
Is it?
Not necessarily.
Why are you floating to different shops?
Old Sep 4, 2015
Wankenstein's Avatar
You stated the transmission is shifting fine...however, a severely slipping transmission would emulate power loss because torque is not being converted properly. Doubt if that is the issue but no harm in doing an ATF drain and fill.
Exhaust leaks near manifold? If it's the exhaust manifold gasket or doughnut it could cause power loss: https://www.google.com/?gws_rd=ssl#q...+leak+symptoms and not throw a CEL.
If your car is low on oil the Vtec may not be engaging but, Vtec wouldn't make a difference at lower RPM's. You or a mechanic need to do some testing:
1) Cylinders compression test: http://troubleshootmyvehicle.com/hon...-compression-1
2) Spark test :http://honda-tech.com/honda-civic-de...blems-2919450/
Wouldn't be surprised if your distributor coil is weak and on it's way out..test first before replacement.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mikebj23
Jul 28, 2015 08:08 PM
wootah88
Jul 21, 2015 10:22 AM
Yazan93
Jul 14, 2015 08:56 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
