VTEC operating ?
Old Aug 19, 2015
MrOldskool's Avatar
got rice?
MrOldskool is an unknown quantity at this point
VTEC operating ?
Hello,
Question with my 97 EX, Even though the 1600 engine has great power for it's size, I don't feel any 'kick' of power at upper rpm's, ie getting on the freeway (have to wind it up in third) How do I know if the cam advance is operating correctly and at what Rpm is it activated? My Ign timing is right on and valves adjusted....
Old Aug 19, 2015
GolNat's Avatar
Prelude Owner
Re: VTEC operating ?
How is your oil level?
If it's low it can keep VTEC from engaging.
Old Aug 19, 2015
actually, low oil could trigger an engine malfunction code/light, so not likely.
if you really concerned, you could rig this:
https://www.civicforums.com/forums/1...tec-light.html
https://www.civicforums.com/forums/2...n-opinion.html
Old Aug 19, 2015
GolNat's Avatar
Prelude Owner
Not low enough to trigger the light but low enough for the oil ports used for VTEC operation to not engage. Part of the the VTEC operation is from oil pressure.
My 94 Accord would do it to me when it was low. No VTEC, add oil
Old Aug 20, 2015
MrOldskool's Avatar
got rice?
Thanks all, I keep the oil full, Is there a set rpm the ecu engages the advance or is it load activated? is the valve on the side of the head for the oil supply to the advance actuators?
Been a Diesel mechanic most of my life... this engine is like a little toy to me
Old Aug 20, 2015
GolNat's Avatar
Prelude Owner
VTEC selonoid could be clogged.
It is a set RPM and uses different feedbacks to engage. You can read the specifics of how it works online.
Old Aug 21, 2015
MrOldskool's Avatar
got rice?
Thanks!! And I was wondering why it does not have the upper end acceleration it did before? Duh... I pulled the front cover and checked timing belt tension and cam to crank timing as well as ignition timing......
I will check into it and follow up with an update!
Old Aug 28, 2015
MrOldskool's Avatar
got rice?
Well I ordered the Vtec gaskets, the unit has been leaking oil a little.
pulled the solenoid actuator off and opened it up, screen was clear. spool valve free, cleaned it all up, tested the pressure switch with air and ohm meter, contacts open under pressure. tested the solenoid with 12v and air, valve opens, blew through the ports in the head. re-installed unit. wired in a LEd to the ecu output and took it for a drive. Led lights at around 5500rpm and I can feel vtec working, but by then its hitting red line...
It seems like it used to come on way sooner like around 4000rpm where it would have better torque... Any suggestions???
Old Aug 28, 2015
GolNat's Avatar
Prelude Owner
D16Y8 has VTEC switchover at 5600 RPM so your close!
https://en.m.wikipedia.org/wiki/Honda_D_engine#D16Y7
Not sure how to move it so it activates lower. Newer Civics it is done through engine management.
Old Aug 28, 2015
MrOldskool's Avatar
got rice?
Thanks a bunch! I know these engines like to rev, but with going on 250,000 miles, id like not to wrap it up to the top to get me on a busy freeway. I was thinking about a override push button switch on the shifter with a blocking diode to keep the 12v power back-feeding the ecu...
Old Sep 2, 2015
MrOldskool's Avatar
got rice?
Anyone have input on this? /\ /\
Old Sep 2, 2015
GolNat's Avatar
Prelude Owner
Blocking diode is a good idea.
So you want the button to prevent VTEC from engaging?
Old Sep 4, 2015
MrOldskool's Avatar
got rice?
Sorry I didn't explain that correctly, I would like to manually kick on the vtec a little earlier say around 4500-5000rpm with a momentary toggle or push button switch. It would still be wired from the ecu, just would not feed back voltage from my 'override switch' to the ecu output... Muuhaaahaa (its alive!)
Old Sep 4, 2015
GolNat's Avatar
Prelude Owner
I don't think that would work. The VTEC also uses hydraulic pressure to activate I don't think it is all voltage controlled. Maybe I am wrong but I don't think sending a signal to the ecu is all that needs to be done.
JetsterDajet
52
May 8, 2016 12:11 AM
Elciteeve
Sep 28, 2015 12:40 PM
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
Bruce2
Sep 21, 2015 08:01 PM
