Shudders on takeoff.
Old Aug 23, 2015
maat922's Avatar
maat922 is an unknown quantity at this point
2000 dx coupe, 5 speed. Out of nowhere today when leaving for work, I let out the clutch and the car shuddered as if the throwout bearing was failing. I've seen this come on slowly in other cars before, but never suddenly like this. Is it simply time to do the clutch? Or is something else causing this?
Old Sep 1, 2015
MrOldskool's Avatar
got rice?
MrOldskool is an unknown quantity at this point
Re: Shudders on takeoff.
In my umpteen years of being a mechanic (cars and heavy truck), Clutch shudder is usually caused by a warped clutch disc, bad pressure plate springs, oil/grease has came in contact with the disc friction material, or a sticking release fork.
A throwout bearing usually makes noise or have excessive travel play and makes it hard to release the clutch... But before pulling the trans, make sure the slave cylinder is returning smoothly.
Hope my 2 cents worth of info helps
Old Sep 1, 2015
tuvok's Avatar
tuvok is an unknown quantity at this point
yeah sounds like warpage to me , id suggest having a new clutch installed and make sure the flywheel gets resurfaced.
mgrantaz
General
May 2, 2022 05:40 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
BryanM.
Aug 29, 2015 03:26 PM
General 7th Gen
Jul 9, 2015 10:17 PM
671civicLX
Jul 4, 2015 04:02 PM
