2000 honda civic no start
Old Jun 3, 2015
carlrock's Avatar
carlrock is an unknown quantity at this point
hello I have a civic 4 cylinder that wont start has fuel and spark in time compression is 130 on 3 cylinder's 80 on 1 wont even try to fire with starting fluid. any ideas dropped the exhaust same thing pulled injectors has normal spray pattern.
Old Jun 3, 2015
GolNat's Avatar
Prelude Owner
Re: 2000 honda civic no start
Thread needs to be moved.
What did the plugs look like?
Any work just done on the car? Did it sit overnight and then wouldn't start one morning?
Old Jun 3, 2015
carlrock's Avatar
plugs are new been sitting for days trying to find problem its not a hot start problem. someone else was chasing this problem before it came to shop.
Old Jun 3, 2015
yep, it's a 6th gen, not a 8th gen, nor it's a helpful DIY article either...
Old Jun 3, 2015
So you are working in a shop?
This car is in your shop?
What kind of shop is it?
Old Jun 3, 2015
carlrock's Avatar
its a full repair shop been in the business 34 years its a friends shop, I don't work there im retired he just called me to see if I could help him out I was a tech for 32
Old Jun 3, 2015
Ah, ok.
130 is way low to me, if I do the compression test I expect 180+.
Are the plugs wet with gas?
Has it lost spark?
Got a scanner? Any codes?
What is the ECT temp when you crank it? Is the ECT reading accurate?
Old Jun 3, 2015
carlrock's Avatar
Originally Posted by ezone
Ah, ok.
Has it lost spark?
no it never looses spark
plugs don't foul no codes 130 is low but you would think it would at least try to start ect is cold 70 in the am he tried starting fluid and no pop even checked timing belt is ok pulled injectors and they spray fine blue spark at plugs no codes its data looks good. dosnt make since
Old Jun 3, 2015
Plug gap is too small to check.
See if the spark will jump a gap of at least a half-inch.
plugs don't foul
Are the plugs WET with gas?
Is it really gasoline?
Contaminated fuel?
Diesel mixed in?
130 is low
Oil the cylinders to restore compression?-- (engine got flooded)
Is the cam gear out of time by a couple teeth?
Is the bolt on the cam gear loose?
Verify TDC mark on the balancer is truly TDC --piston 1 at the top?
Checked ignition timing with a timing light? (I know it won't run, just check it while cranking)
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
gabrown2
Apr 11, 2015 08:22 PM
liljoe
Nov 4, 2001 01:27 PM
