Changed fuel filter, car cranks but wont start!!
im a new member on these forums, and im not the most experienced on working on cars. Ive done quit a few simple basic maintenance on cars over the years but i messed something up on my 97 civic lx.
just earlier today the car was running great. started up fine with no CEL codes or anything. i buy a new fuel filter and proceed to change it. i first start the car up and have it idle, then while its running, i removed the fuel relay fuse under the dash and the car died as expected after a few seconds. i disconnect the negative batt terminal, and proceed to swap out the filter.
after installing the new filter, i hook the batt back up, replace the fuse, and turn the key to the on position to let the system pressurize. i try to start it, but it wont turn over....just cranks and cranks. I check the filter, and its leaking slightly at the top fitting, so i take it off and try to readjust the new washers it came with.
after doing that a few times, it still kept leaking so i decided to not deal with the leaking filter and put my old filter back on and with the old washer. NOW no leaks. the system pressurizes and im able to get plenty of fuel through the old filter.
car still wont start though. i replaced the main relay and still doesnt start. battery is fine as well. i took the plugs out and each of them was wet with gasoline.
my guess is that i somehow flooded the system and thats why it wont start??
i really dont know, and i dont have many tools or expertise to dig into the whole engine.
Re: Changed fuel filter, car cranks but wont start!!
If it's flooded, then to clear it, push the accelerator pedal all the way in while cranking. This disables the fuel injectors and will eventually clear it. I had this happen to me last summer when I moved the car 10 ft down my driveway so I could use a ladder where the car used to be. (I don't do that anymore...)
Did you line up the banjo bolt correctly on the top of the filter?? This bolt has a hole in it that has to be facing the correct side or it will not be able to feed fuel to the engine. It is best to mark the head of the bolt where the hole is so you can tighten it down, if you can not get correct alignment when you tighten the bolt, add a skinny washer to the bolt and tighten it again.
I would retrace your steps and see if you maybe bumped something else while under the hood. If the problem did not exist before, then it must be something you touched. I have not heard of unplugging the relay while the car is running. Is there a reason for that procedure?
Kill pump, run engine til it quits, fuel line pressure is lowered.
Lower pressure = less spraying when you crack a line open.
These cars don't have the valve on the rail do they?
I just let the fuel come out of the filter, it's low pressure. If I did it for a living, I might care more about getting gas on me and fumes in the garage.
Digging for a way to kill a pump takes too long. I usually throw a rag over and let it spray LOL
mistermenphis22
Apr 3, 2016 08:06 AM
dooner24
Apr 14, 2015 07:51 PM
