Car wont run please help!
Old Feb 7, 2015
JMP124's Avatar
JMP124 is an unknown quantity at this point
2000 honda civic ex A/T 202000mi
d4 light started blinking the other day and speedo was jumping
it wouldnt keep speed with cruise control
i tried a new speed sensor didnt change anything.
today i was driving and car lurched and died.
engine light was flickering
i put it in park and turned key all the way off and back on car started goes a few more miles till i get home
in my garage now car will only crank not start and the d4 light and engine light flicker.
good battery and good connection to battery.
good trans fluid level and oil level.
opened ecu no burnt spots and circuit board(it could still be bad)
im going to check visible ground points under hood hope for the best.
please help!
Old Feb 7, 2015
Re: Car wont run please help!
Can you pull any codes?
Check grounds on the thermostat housing?
IDK.....
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
15
Aug 19, 2015 03:12 AM
dragonsblood
Apr 27, 2015 12:28 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
