Installed a car amp, now engine turns but doesn't start.
Old Feb 8, 2015
bleeper4's Avatar
bleeper4 is an unknown quantity at this point
Hey guys, been lurking around for a while but never signed up to the forums.
I just installed a simple 600W amp for a sub this weekend, and followed every step to the T: wired the power cable with a fuse, ran the cable through a rubber seal in the firewall, etc. Finished the job today and went to start my car, but all it does it turn for days and never start.
I'm pretty certain it's not the battery because 1) I never actually see the amp turn on (a problem for later, probably has to do with the remote wire), 2) all electronics run fine, including the starter, and 3) I tried starting the car with another car jumpered to my battery and it still doesn't start. All it does and turn and turn (and it turns well). I've never had a problem starting within a few cranks before.
The only thing that I did that was sketchy was that I used a knife to poke the hole through the rubber seal in the firewall, to run my power cable. The rubber seal is at the feet of the passenger's side under the dash, and holds what looks like the majority of signal wires going through the firewall. I cut about 1/2" away from all the wires, so I thought I didn't touch them, but my only hypothesis right now is that I cut some wire that makes sure the engine is turning and lets the car start.
I'm asking you guys more knowledgeable with the starting signals of the Civic: is this possible? For a broken wire to let the starter crank the engine but never let it fully start? Or am I on the wrong track? Thanks in advance. I'd hate to have to spend $$ to get this thing towed and looked at at a shop. This was supposed to be a cheap ($75) investment!
Old Feb 8, 2015
Stock 99's Avatar
Re: Installed a car amp, now engine turns but doesn't start.
I'd check the main fuses under the hood you probably blew one (80 amp) I think is the main one. Should check both under the hood and drivers side before looking anywhere else though.
Old Feb 8, 2015
bleeper4's Avatar
You were right! Blew the ECU fuse. Not sure how but at least my car starts now! Feelin kinda dumb but not as dumb as if I got it towed and laughed at by the mechanics. Thanks!
Old Feb 8, 2015
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Did you disconnect the battery before wiring up the amp? If not, that's how you blew it.
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
smmahan
Apr 15, 2015 08:17 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
