RPM Fluctuates Above 4k, need help!
Old Jan 9, 2015
Terry R's Avatar
Terry R is an unknown quantity at this point
The other day my car didn't start. Long story short, I had to replace the Ignition Control Module (igniter). The car starts and runs fine now. The only exception is that the car cuts out and the RPMs fluctuate above 4k. Any advice is much appreciated.
It is a 98 Civic EX 5 Speed with 150k miles
Old Jan 9, 2015
Re: RPM Fluctuates Above 4k, need help!
I'll guess:
One or more of the female wire terminals that you connected to the igniter isn't correctly installed (male blade went between the boot and terminal instead of into the middle of the terminal)
OR female terminals are not gripping the male blades tightly and needs crimped a little tighter.
See the 2nd page of this service bulletin for more info: http://www.tegger.com/hondafaq/p0420/A05-027.pdf
If you are careful you can do this with pliers.
HTH
Old Jan 9, 2015
Terry R's Avatar
Thank you very much for the response, I will take a look at it tomorrow.
Old Jan 10, 2015
Terry R's Avatar
I messed with the wires to the module this morning. It now cuts out at 3,100 RPM so I believe that is my problem. I will try to mess with it tomorrow in a heated garage. Thanks again for the help!
Old Jan 10, 2015
Terry R's Avatar
I got it fixed! I messed with the wires again using pliers. I also got new screws to attach the ICM to its mount. For some reason the original ICM is a slightly different shape than the new one. The new one was loose on the mount, but not anymore. I should have taken pics but at least she's running like normal. Thanks again!
Old Jan 10, 2015
Glad to hear it!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 27, 2015 08:45 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
Bricoleur
Sep 9, 2015 12:23 PM
