thermostat?
Old Nov 10, 2014
civic98?'s Avatar
civic98? is an unknown quantity at this point
thermostat?
Would a thermostat cause the heat to go from warm to cool and then warm? It doesn't over heat or anything the coolant is good but it does bubble. I just don't see any way of a head gasket. The temp gauges stays in the middle normal area never goes up past normal.
Old Nov 10, 2014
Re: thermostat?
Could.
but it does bubble.
Why would a full cooling system do this?
Then explain the above question.
Old Nov 10, 2014
civic98?'s Avatar
Re: thermostat?
Was thinking it wasn't opening correctly. I had it tested at a shop were they used a fluid to test the coolant and it was good. It don't get hot,smoke, or have water in the oil that's why I wasn't sure of head gasket. It does push it out into the overflow.
Old Nov 10, 2014
Re: thermostat?
Many blown head gaskets will pass all those common checks with flying colors.
A head gasket has maybe a dozen different jobs to do. Most people only look for about 3 or 4 of the more common failure areas.
They all do this as part of normal fluid expansion when heated, but the reservoir is supposed to go back to the original level when the engine cools down. And the radiator is supposed to stay completely full under all conditions.
If it fills the overflow reservoir while at the same time the radiator goes low.....
Read up on all the stuff about 7th gen head gasket issues.
6th gen uses the same gasket design.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Munzy
21
Oct 7, 2015 07:48 AM
david34
Sep 23, 2015 11:13 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
tooly145
Sep 5, 2015 01:05 AM
