1999 civic speedometer problems
Old Nov 7, 2014
steamer454's Avatar
steamer454 is an unknown quantity at this point
Hi, new to the sight. Thursday morning on my way to work speedo quit check engine light came on. After work checked fuses seemed ok. checked speed sensor wires looked good. This morning on my way to work lights kept getting dimmer, then srs light came on vehicle died. After work it started drove home if I tried light it would start to die. Removed alternator had tested it's ok battery is one year old. What do I need to check?
Old Nov 7, 2014
Re: 1999 civic speedometer problems
Hi, new to the sight. Thursday morning on my way to work.....
......What do I need to check?
EDIT: Damn, I still can't read.
You got codes? What codes does it have?
Check fuse #15 in the dash fusebox.
Old Nov 8, 2014
steamer454's Avatar
Yes fuse 15 is good and no did not check any codes. Just believed since it was dragging battery down alternator was bad I'm old school. Would bad speed sensor pull battery down.
Old Nov 8, 2014
I'd check codes just to see what possible helpful info I could gain. Maybe it's all related, maybe not.
Next I'd grab a wire diagram and voltmeter and do some real testing....I'd hate to replace perfectly good parts.
I suppose yes if the fuse is blown, since it feeds both of those items plus several other sensors: Alt, VSS, ELD, EVAP controls solenoids, both O2 sensors......(again, check for codes, could be a wiring problem or something if it ate through a wire).
See this bulletin link: http://www.tegger.com/hondafaq/misc/...%2315_fuse.pdf
But a plain old sensor failure also damaging the alternator? No, I can't see it.
I'm old school.
I can be old school too (grew up with points and carbs, and fuel injection was just a passing fad LOL).....but I must be able to grasp all of the modern tech and really figure stuff out in order to get paid and keep my customers.
HTH
Old Nov 8, 2014
steamer454's Avatar
Ok I will install alternator tomorrow. Then will run it to advance to have them read code. Still something is taking charge out of battery. I would think alternator could keep up.
Old Nov 8, 2014
In the alternator 4 wire plug: Test the blk/yel wire for 12v+ with the key on.
If that tests as 0v, that's why it wouldn't charge.
Old Nov 8, 2014
steamer454's Avatar
Ok what is feeding blk/yellow wire
Old Nov 8, 2014
Fuse 15 in the dash fusebox is supposed to give that wire power, with the key in the run position.........
Old Nov 9, 2014
steamer454's Avatar
Ok so I put alternator back in. Checked fuse 15 this time it is blown. Not quite sure why now you can see it. It checked good when I used meter. I know it sounds weird. And yes I do know how to use a meter as a 25 year tech my life depends on it. So all lights cleared speedometer works. Sure it will come back things don't fix there selves.
Old Nov 9, 2014
Read the bulletin linked in my previous post.
That tells where to find the short and how to fix it.
HTH
Old Nov 9, 2014
steamer454's Avatar
HTH
Sorry I missed it. But ezone that was the problem. Thanks for your time. It only cost me a little time. 99 civic work car with 170000 plus miles is back. Thanks.
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
dragonsblood
Apr 27, 2015 12:28 PM
aultman1990
Apr 19, 2015 07:14 AM
smmahan
Apr 15, 2015 08:17 PM
