08 Civic idling rough, shifting late
Old Sep 5, 2014
xhasti's Avatar
xhasti is an unknown quantity at this point
I have an 08 Civic LX coupe with automatic transmission and 65K miles. About 6 months ago it started idling rough and kind of trembling/shaking on startup. When I backed out of the driveway and put it in D and gunned it up the street it would pretty much immediately go away. Replaced air filter and ran a fuel treatment through to no avail.
I took it to a mechanic and he said he didn't think there was anything wrong with it, said the computer was very sensitive and it would throw a check engine light if anything was wrong. He said plugs were not due for changing until like 105K
Since then the rough idle has gotten worse. Sometimes when I start it my keys even start shaking hanging from the ignition. And I have also noticed that quite often it seems to be revving higher than it used to before it shifts gears.
Any idea what might be going on?
Old Sep 5, 2014
Re: 08 Civic idling rough, shifting late
put it in D and gunned it ....... immediately go away.
Hard loud rough vibrating: Motor mount has been common, the one large mount on the nose of the engine is the one that goes bad.
Check out the good/bad pics of a mount in this post: https://www.civicforums.com/forums/1...ml#post4577741
See if that mount may be your problem first.
Old Sep 8, 2014
xhasti's Avatar
Can you tell from looking at this if the mount is bad?
Old Sep 8, 2014
193drtelco's Avatar
193drtelco is an unknown quantity at this point
I'm having the same problem with my 08 POS. Motor mounts, transmission mounts were all replaced.....they were all bad, but I still have a terrible vibration. It is a bit better, but it seems the vibration will damage the new mounts in no time....any ideas?
Old Sep 8, 2014
Looks like it's collapsed. There's little or no gap between the upper and lower halves.
Compare to these pics (courtesy of Gunner)
Bad:
Good:
HTH
Old Sep 8, 2014
Throw away the aftermarket mounts.
Install factory mounts.
I've not yet seen any of these cars that needed any more than the one at the nose of the engine anyway, pictured above.
mikemc422
Aug 9, 2018 05:41 PM
dragonsblood
Apr 27, 2015 12:28 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
