Trunk won't lock
Trunk won't lock
Hey guys,
I just got myself a 2000 Honda Civic hatchback DX Special Edition (I'm in Canada). The car looks and drives great. I only have one problem (I searched but I couldn't find what I'm looking for. Maybe I missed a similar thread).
Today, I randomly decided to see if my trunk was locked and I realized it wasn't. When I tried to lock it, the little stick (sorry I don't know the parts name) goes down when I lock the trunk. However, the latch does not move. I can move the latch myself to put it in the closed position, but then I am not able to close the trunk. Pulling the trunk handle makes the latch go in the open position, regardless if the trunk is locked or not.
I removed the plastic cover to see if anything is missing or not connected but I couldn't determine anything being wrong.
So I was wondering if someone had a similar issue previously and knows how to solve it or knows where I can find a DIY. Any help is greatly appreciated and I hope this post will be the first of many for me.
Thanks
Thanks
Re: Trunk won't lock
I can't see for myself what it's doing, so I'll take a wild stab:
The manual says you should be able to close the hatch and then use the key to unlock and lock it.
Or push the lock **** down and close the hatch to lock it.
Outside handle should not open the hatch at this point until the key is used to unlock it.
It's got about 15 years worth of dirt and grime in the mechanisms, maybe it needs some cleaning and lubrication.
Does the outer handle have full range of movement?
Anything in the mechanisms binding from rust?
Does the car have an inside release cable by the drivers seat?
Striker or latch not in correct position? Bent? Loose or damaged?
EDIT: Welcome to the forum!
This is how the latch is
And once I close the trunk the latch should be like this around the striker no? I used a screwdriver to push it like that.
No inside release. Striker is fine. I think the latch is fine (you can tell me from the 2 pics I posted). Thank you for the help and the warm welcome to the forum!
Little update
So the latch actually works fine. And the lock cylinder and cylinder rod work as well.
I think if the car is unlocked, when you press the trunk handle it should release the latch and if the car is locked, something should block that from happening. And for reason xyz, the trunk handle releases the latch regardless if the trunk is locked or not. So is there a missing part? Is a part broken? What could it be?
Again thanks for all the help.
Here are some pics if it can help
I still can't tell much from your pics, and I don't think pics would help me to watch it all in operation.
I'd take a wildass guess and say put a new latch in it.
DerbyDad03
Exterior
May 16, 2021 10:07 AM
geoffm1234
Exterior DIY
Jun 3, 2015 08:18 PM
Youshoe
May 22, 2015 09:36 PM
