Bracket for fuel filter
Old Jun 16, 2014
civic_o's Avatar
civic_o is an unknown quantity at this point
Hello,
I was in the process of replacing my fuel filter when I drop the bolt (10 mm) that held the filter in place on the bracket itself. I can't seem to find it so I'll have to get a replacement - anyone care to share the specs of said bolt?
You'll have to excuse me, I'm a rookie not only when it comes to auto repairs but Civics as well.
Much appreciated!
David
Old Jun 16, 2014
Poopies's Avatar
Super Moderator
Re: Bracket for fuel filter
I don't know what generation Civic you have, but most of the 10mm bolts are pretty similar in mine. Just pull another extra one out of your engine bay that looks about right (and isn't holding anything together) when you get to a hardware store and show it to them. Or, you can check out this site for the official part.
Old Jun 17, 2014
Random 6th gen pic:
Bolt and nut, #32 and 36?
Catalog says 6mm x 24mm for most of the cars, but one version uses 6 x 12.
Use however long a bolt will fit and work?
6mm is the diameter of the threaded part. The head is 10mm wrench size.
Old Jun 17, 2014
civic_o's Avatar
Bolt and nut #48, perhaps it's not as long as the other two bolts you mentioned. Is it also 6 mm in diameter?
Old Jun 17, 2014
Bolt ...... #48,
Random lookup said 6x16.
Too bad we still have no clue what sort of car you have.
Old Jun 17, 2014
civic_o's Avatar
Sorry, it's a 2000 civic, gen 6, I believe.
By the looks of it, Bolt 48 may not be it, unless it specifically states that it goes into the bracket. It may very well be Bolt 30.
Old Jun 17, 2014
More specifically:
2 door? 3 door? 4 door? 5 door?
EX? LX? DX? HX? Si? CX? GX?
Your country? (I already know where you are)
Canada market cars are not always the same as USA market cars.
All the choices can make a huge difference in parts. Not all cars with 4 wheels are the same.
Yes that's 6th gen.
Look up what you need in one of the many online parts catalogs.
http://www.hondaautomotiveparts.com/
http://estore.honda.com/
30 threads in to 29.
29 attaches the fuel line to the top of the filter.
Civic15
18
Sep 19, 2017 07:48 PM
mjdiaz89
Jun 21, 2016 09:26 PM
0396
May 4, 2016 07:14 AM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
