97 Civic d16y7 idle surge - air wont completelybleed.
Old Jun 6, 2014
Will1980's Avatar
Will1980 is an unknown quantity at this point
97 civic lx - d16y7 - manual - 167,000
I recently changed the timing belt and water pump. Since then I have had idle fluctuation/surge unless the fan for the A/C or Heat is turned on. With heat on full I have tried to bleed the system for 4-5 hours but it continues to bubble and the surge continues. Fan cycles normally and the thermostat seems to open as it should. I am using the proper funnel. I ran the heat on high. I thought for sure I had a bad head gasket but I have run a block test 3 times and it comes back negative. The car does not miss, overheat, or lose water. No steam or smell from exhaust. I have not checked the IACV or the FACV, as the problem started immediately after I did the water pump service I assume the problem is air in the system. I am pretty sure that my 97 model does not have a bleeder valve but I could be missing something. Any help would be greatly appreciated.
Looking for the answers and I haven't found any. I feel blind right now but I'm sure hind sight will be 20/20.
Old Jun 6, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: 97 Civic d16y7 idle surge - air wont completelybleed.
This is a 6th-gen forum question.
mikemc422
Aug 9, 2018 05:41 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
