Problem with idling when stuck in traffic
Old May 25, 2014
tattoobc's Avatar
tattoobc is an unknown quantity at this point
I just bought my first Honda, it is a 1997 LX sedan. Car drives nice except when i am a traffic jam. After taking it out of gear to come to a stop the idle goes to anywhere between 2500-3000- rpms. If i tap the gas it helps sometimes. Other than that it never does it in normal traffic. Any ideas on the problem?
Old May 27, 2014
Poopies's Avatar
Super Moderator
Re: Problem with idling when stuck in traffic
You have manual or auto? You could check the transmission fluid or the IAC valve to start.
Old May 27, 2014
tattoobc's Avatar
It is a Manual. Will do! Thank you for the reply.
Old May 27, 2014
Poopies's Avatar
Super Moderator
HTH, keep us posted on what you find!
Old Jun 18, 2014
Digitalism's Avatar
Digitalism is an unknown quantity at this point
High idle when the engine is warm could mean a few things.
Check the transmission fluid, as previously posted, and also check your Idle Air Control Valve. I had a similar issue with my Civic, and a cleanup of the ICV and throttle body put me back to normal.
I made a little How-to in a previous thread:
https://www.civicforums.com/forums/2...lp-please.html
Post #17
Good luck!
mikemc422
Aug 9, 2018 05:41 PM
Wild Cranker
427
Jan 28, 2016 06:49 PM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
