where is crankshaft positioning sensor in 1999 d16y8?
Old May 15, 2014
clb235881's Avatar
clb235881 is an unknown quantity at this point
Ok, this may be a stupid question. But I have seen multiple answers . where is the crankshaft positioning sensor in my 1999 civic ex (d16y8)? I have heard some say it's in the distributor, and some say that it's behind the crankshaft pully and lower timing belt cover... Help!!! The symptoms of my car are that of a faulty crankshaft position sensor. But where is it located???
Old May 15, 2014
Re: where is crankshaft positioning sensor in 1999 d16y8?
It has both, depending on your definition.
One of three sensors inside the distributor functions as the CKP sensor.
The sensor on the end of the crankshaft (CKF) is used as a misfire sensor on your engine.
7th gens use a nearly identical sensor on the end of the crankshaft as the CKP.
What symptoms?
What code do you have?
159
Jul 5, 2015 09:54 PM
Supramk3
Jun 11, 2015 11:13 AM
Flipg123
May 8, 2015 01:15 PM
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
