d16y8 Smoke Problem (PLEEASEEE HELPP)
Old Apr 29, 2014
xXdestroyerXx73's Avatar
xXdestroyerXx73 is an unknown quantity at this point
Exclamation d16y8 Smoke Problem (PLEEASEEE HELPP)
i have a 1999 honda civic d16y8 that smokes when i throttle up.. it idles @ 1200-1900 rpm ( no idea why.. ) and if i start to throttle up towards 3000-6000 rpm it will smoke really bad... i cant figure it out, the only part i have on it that does anything to engine is a cold air intake ( im too worried to put other parts on it because of the smoke) i cant fix it... ive tried cleaning the throttle ... i tried compression tests ( range 130-150 )
and i cant figure it out.. the smoke is white... help me pleaseeee
Old Apr 29, 2014
Re: d16y8 Smoke Problem (PLEEASEEE HELPP)
Is the engine using coolant, or is it using oil?
Miles on the engine?
Old Apr 30, 2014
i dont know if its using coolant but i know its not using oil. and it has about 160xxx on the engine
Old Apr 30, 2014
Blue (oil) smoke @ high RPM is usually rings.
The smoke may be very pale blue.
thana
Jun 15, 2020 07:05 PM
159
Jul 5, 2015 09:54 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
