Annoying Oil Leak!!
Annoying Oil Leak!!
First let me say I understand that these kind of issues are very popular among civic forums and have spent many hours searching said forums for possible solutions. Without really seeing the car in person its very difficult to make any recommendation I would assume. However, here goes:
I have a 1999 Civic EX sedan with 170,000 miles and Manual Trans. Overall it has been very good to me over the years. However, It has developed a large oil leak. I don't get puddles on the ground, but the engine bay is very messy. I have replaced the following:
Oil Pan seal
Vtec Gasket
Distributor Gasket
in efforts to find the leak. I used UV dye and that didn't help much at all. I see oil in a couple of key areas.
(1) underneath the distributor - however is not leaking externally or internally I am guessing the alternator sits right under there and I can see some oil on the housing.
(2) between the engine and firewall - mainly driver side towards the rear of the engine. With limited visibility it kind of seems like there might be something leaking heavily right above the oil filter. ? I don't know what this could be.
Valve cover gasket does not appear to be leaking oil.
Any thoughts? I would like to do the work myself, but having cleaned it numerous times I can't seem to find where the actual oil is coming from.
Help!
Oil Pan seal
Vtec Gasket
Distributor Gasket
Help!
Re: Annoying Oil Leak!!
I have thought that there might indeed be a leak at or near the oil sending unit (or switch). Wouldn't the oil pressure check light come on in the dash if there was a leak of so much oil from there? There has been a couple times when it appears to be very little on the dip stick. It strikes me as weird as there was no drop in pressure with that little oil in the engine..??
Occasionally a leaky switch loses its calibration and causes the light to stay on when it shouldn't, but certainly not always.
The dipstick marks represent only a quart between high and low marks. The crankcase holds about 3.5 quarts.
HTH
Could a leaky oil sending switch really leak much oil?
Is a leak at this switch common?
Would there be anything in the same vicinity that would cause this annoying leak?
Thanks to all for the help.
Oh yeah, there's full system pressure behind it at all times.
Old age and high mileage, sure.
We try to keep a few on hand at work.
Get under it and start looking. Take a mirror and flashlight with you.
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
