98 Civic lock actuator problem
Old Apr 28, 2014
Kenjitsu's Avatar
Kenjitsu is an unknown quantity at this point
First off, I would imagine that one could lock the driver's door from outside with a key, right? the lock won't let me close it.
When I try, I can see the lock release handle on the inside kind of move, but it feels like the locking mechanism is "stuck" or something.
Also, the passenger side seems like it's weak when I try to use the power lock feature. Does these actuators go bad often?
Thanks for any input.
Old Apr 28, 2014
Re: 98 Civic lock actuator problem
You know about pulling a handle out before you can lock or unlock with the door open, right?
Um, pull the panel off and see of any of the linkage/rods has been gooeyd with tar or glue from the inner liner.
Then poke around to see why your lock and latch don't do as they should. Bent? Rusted? Seized? Damaged?
Yes, actuators do get weak and go bad.
Old Apr 29, 2014
Kenjitsu's Avatar
So when you pull the handle to lock/unlock one doesn't pull to far out on the handle, right? I'll try that.
Thanks for the tips.
CarStuff
Dec 6, 2020 12:52 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
darwin-t
Apr 18, 2015 09:29 PM
Killagi
Apr 12, 2015 10:42 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
