starting issue
Old Apr 12, 2014
EJC98civic's Avatar
EJC98civic is an unknown quantity at this point
starting issue
hey im brand new to this forum I've had my 1998 civic LX for over a year now never had any problems with it till my clutch started going out at the end of January so I stopped driving it and starting driving my accord wanted to wait for the weather to get nicer before I start to replace the clutch in the civic, Anyway the last time I started it was the beginning of march so like 6 or 7 weeks when I went so try to fire it up 2 weeks ago it wouldn't start it had spark but it was week so I did a little tune up got new NGK plugs, wires and got a new distributor cap an rotor button, o an new battery . Plugs had fuel on them when I changed them so now im trying to test fuel pressure?
Does anybody know what the fuel pressure should be while key is ON but engine is OFF and what it should go to while cranking? on a 1998 Honda civic LX 1.6L
any help would be appreciated
Old Apr 12, 2014
Re: starting issue
Welcome!
If you have wet plugs, fuel pressure probably isn't the problem.
At the plug wire ends: Will the spark jump about a 1/2 inch gap? It needs to be able to jump at least that far.
My guess: Flooded and lost compression.
Dry the plugs,
disable spark and fuel
crank the engine with the plugs out (to blow out excess gasoline)
then add a teaspoon of oil into each cylinder, (to restore oil to the rings)
crank it again, (to blow out any excess oil)
then reinstall the plugs and reconnect the distributor and injectors.
Crank it. If it fires and runs, then great. Move it outside, it will smoke. Drive it!!!! Or at least let it get up to operating temperature before you shut it off.
If it only tries to fire, then hold the gas pedal to the floor while cranking, this shuts off the fuel injectors. You can control fuel injecting (on or off) with the gas pedal while operating the starter. If you do it right and there are no other problems, you can get it to run this way.
Old Apr 12, 2014
EJC98civic's Avatar
Re: starting issue
Ok thanks Ezone ill give it a try first thing in the morning, got to go to work right now or I would try it now, if anyone else has any ideas throw them at me!!!!
OR if anyone knows the what the fuel pressure should be let me know! I would like to know for my general knowledge about my car
Old Apr 12, 2014
Re: starting issue
Originally Posted by ejc98civic
or if anyone knows the what the fuel pressure should be let me know! I would like to know for my general knowledge about my car
38-46 psi
Old Aug 30, 2014
Juicetain's Avatar
Juicetain is an unknown quantity at this point
Re: starting issue
Hey. Srry in advance if Im posting in the wrong place or w/e. But im having a serious issue with my civic. I had bought a 1998 civic with no engine and ordered a used one from quebec. The issue is, when I bought the car the previous owner thought they were putting a vtech in it and they cut the wire harness.(i know its just a clip how lazy do yu have to be.) But anyway i didnt want to spend big money on a harness so I used one out of a 1999. I installed the harness the engine and even switched out the computer and distributor. I went to start it and it turns over with no fire. I followed it back to the distributor (inside) and still couldnt find any power. If theres no power going to the distributor where would I go from there? Im no expert on civics or even in mechanics but a basic stock engine swap shouldnt be this big of an issue. I dont know what im missing but ive had the car for some time and its gunna end up being to far gone if i dont get it going soon. Any help or thoughts would help me greatly.
Old Aug 30, 2014
Re: starting issue
Fuseboxes (both).....
wiring diagrams and voltmeter, trace it out
Old Oct 3, 2014
AF-BioTech's Avatar
AF-BioTech is an unknown quantity at this point
Angry Re: starting issue
I too am having issues with my 99 clivic, I dont have any spark, replaced entire distributor, Crank shaft position sensor and the main relay under the pass side behind the glove box. Im getting fuel, good compression just STILL no spark. Please any help would be wonderful.
ayoitzjulesdx98
May 13, 2015 08:31 PM
jetcare101
May 8, 2015 01:33 PM
civic_gt
Apr 19, 2015 08:15 AM
black2k1vtec
Dec 6, 2001 09:49 PM
