Fuel gauge issue?
Old Apr 5, 2011
strega51's Avatar
strega51 is an unknown quantity at this point
Unhappy Fuel gauge issue?
My daughter's 98 EX has a fuel gauge problem. It will read normal sometime and then show past full most of the time. Because of Honda's easy access to the sending unit I replaced it. Problem still the same.
Any suggestions?
Old Apr 5, 2011
Re: Fuel gauge issue?
could be a faulty fuel gauge in the cluster. may want to check ebay and try a replacement. usually fuel senders going bad only affect the reading within the defined parameters of the gauge (meaning, it will not cause the gauge to go above its range of motion).
Old Apr 6, 2011
strega51's Avatar
OK, I wish I would have found this forum before I dropped $100.00 on a new sending unit. Are these gauge clusters known to have issues? This will be the second one. I replaced one after the speedo was not reading correctly. Could it possibly be a ground issue?
Old Apr 6, 2011
its possible but then nothing in the cluster would work. if the gas is the only problem, id say bad gauge. they dont make em like they do now unfortunately. the newer civic clusters are much more advanced compared to the old stuff. if it has an analog odometer (not digital) chances are the unit will have issues. technology was just too limited back then.
Old Apr 7, 2011
strega51's Avatar
Thanks for the replies. I guess I'm looking for another gauge cluster. I told
my daughter just to use her trip odometer, but she'd like it to work.
Any idea's where to purchase? I've tried local junk yard's no luck.
Thanks,again
Old Apr 7, 2011
have you checked ebay? alot of used clusters there and you can look for one with similar mileage.
Old Apr 8, 2011
strega51's Avatar
Found one. Thanks again.
Old May 1, 2011
Rtenberge's Avatar
Rtenberge is an unknown quantity at this point
Any suggestions?
I am having the same issue with my 1998 LX. Any suggestions?
Old May 4, 2011
Mr.Cordova's Avatar
Mr.Cordova is an unknown quantity at this point
Hey Gearbox or anyone that can help
Quick question, do you know if the fuel sending unit is in the trunk underneath the spare tire on a 2000 civic LX? I found what looks like it would be, i guess the previous owner or dealership put like tar or caulking over half of it!!!!!
Old May 5, 2011
nsxvtec's Avatar
nsxvtec will become famous soon enough
if you have a difficult time finding the fuel and temp gauge units from the instrument cluster and don't want to spend big bucks at the dealership, the gauges can be repaired. Usually one of the thin copper wires wound on the coil around the needle breaks off at the cold soldered joint (there are 4 connections/terminals). Patience and a bit of careful soldering can reconnect the wire and the gauge reads fine again.
just did a 98 civic cluster that was reading "Full' and "Hot" all the time. The gauge has to be taken out of the cluster (3 screws) and the back metal cover removed to clearly see the copper wound coil and the wires if any are broken.
Old May 5, 2011
they do not sell individual parts of the cluster, only the whole thing. and with clusters selling for $100 or less on ebay, it seems easier to just replace the whole thing. just find one with similar mileage.
Old Oct 3, 2014
jds2726's Avatar
jds2726 is an unknown quantity at this point
Question Re: Fuel gauge issue?
My honda civic dx 98 hath has a similar problem.. the gauge reads but only reads abouve 1/2 tank. I tested the sending unit with the voltmeter and it reads a full range (~4 to ~106 ohms) so, thinking it might be the gauge, hooked up the meter to the back of the fuel gauge on the instrument cluster. But when the sending unit reads ~106 ohms the wiring going into the back of the gauge reads ~43 ohms. I have no clue what could be causing it..
mistermenphis22
Apr 3, 2016 08:06 AM
Allecr3
May 22, 2015 01:24 PM
werdnahall
May 17, 2015 11:37 AM
McD
Apr 29, 2015 03:50 PM
htowncivicEX
Jan 21, 2002 11:48 AM
