Aftermarket radio problem
Old 02-15-2014
Civicex2000's Avatar
Civicex2000 is an unknown quantity at this point
I replaced my stock radio with an aftermarket kenwood one and it worked perfectly fine. However that same night I hopped in my car and realized the interior dash lights didn't work (heat, ac, speedometer, gas gauge, etc.) but the dome and overhead lights did. So I took it out and replaced everything, respliced the wires yadda yadda, now the interior lights work but the radio will not turn on at all. So i checked all the wires again, respliced them and the radio just won't won't turn on. The radio fuse is good and so is the radio fuse in the fuse box, all the wires are connected properly as well. Is it possible I fried my radio somehow? Or is there a specific wire I should look check on? Please help thank you
Old 02-15-2014
Re: Aftermarket radio problem
Back up fuse in the engine compartment box?
Old 02-15-2014
I did not check that...is there a radio fuse there?
Old 02-15-2014
Check the
Old 02-15-2014
That was it!! Radio works thank you!
Youshoe
05-22-2015 09:36 PM
paddystrang
05-18-2015 09:56 PM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
mugenca
04-16-2015 12:15 AM
Quick Reply: Aftermarket radio problem
