Automatic transmission shifts at high rpm all gears
Old 02-13-2014
1MORE930's Avatar
1MORE930 is an unknown quantity at this point
my 98 Civic EX will only shift to the next gear at a high rpm. It shifts good when it does shift but you have to be at 4800 rpm. If you let off of the the gas before 4800 rpm it will not shift and stays in whatever gear you are in. the check engine light is on with the code P0122 throttle position sensor. I dont know if that has anything to do with it.
Any help would be appreciated.
Old 02-13-2014
Re: Automatic transmission shifts at high rpm all gears
Fix the TPS code and your trans shifting complaint will magically disappear.
EDIT: Fix the TPS code CORRECTLY....
cruisers10
05-12-2015 10:46 PM
Marcus2thextrem
05-10-2015 03:08 PM
Ninetyatecivic
05-09-2015 07:48 PM
Flipg123
05-08-2015 01:15 PM
ModNewbieHELPME
11-30-2001 06:13 PM
Quick Reply: Automatic transmission shifts at high rpm all gears
