99 civic bad water pump cause engine to die?
Old Feb 8, 2014
dmatlo00's Avatar
dmatlo00 is an unknown quantity at this point
I was driving down the interstate when suddenly engine died (felt like ran out of gas but have full tank) car was normal temp. Car would turn over, but wouldn't start. looked under the hood coolant was all over the passenger side near back of engine and fire wall. I have had a small coolant leak prior to this. Radiator looks ok but was completely empty (cap was not hot at all after driving for 45 minutes!) as was the reserve, appeared that the coolant came from back side of engine. I am not a mechanic, but my guess is the water pump quit. Is this possible without the engine over heating? Is there a setting that shuts engine off when water pump quits, or could it effect the timing belt which caused it to die and not start? From what i read it could be lots of things, but from the fact that coolant was everywhere i assume it has to do with water pump. Sorry i am a very novice mechanic and may not be able to explain things well but please help! Car is currently setting on the interstate waiting to be towed.
Old Feb 8, 2014
Poopies's Avatar
Super Moderator
Re: 99 civic bad water pump cause engine to die?
That doesn't sound like a water pump issue because it was doing its job and pumping the coolant out of whatever hole you have in the system! It doesn't sound like you blew the head gasket since it drained so quickly, so you might have gotten lucky and it's just a blown hose. That's a relatively quick fix. You should try to pinpoint that leak ASAP.
Old Feb 8, 2014
Step #1: Refill the cooling system and figure out exactly what is leaking.
THEN you can figure out what happened and why.
^^^This guy says....
you popped a heater hose......
under the distributor......
it was ruined by.....
soaking in oil leaks.......
until the rubber.....
rotted and got weak.......
........and the distributor cap got wet and killed the engine.........
<<<end of transmission>>>
Old Feb 8, 2014
Poopies's Avatar
Super Moderator
Dammit ezone, your answers are always so much cooler than mine! :-P
Old Feb 8, 2014
It was early for me. No coffee.
mattdoc
Mar 14, 2017 12:10 PM
McD
Apr 29, 2015 03:50 PM
chgofirefighter
Apr 18, 2015 08:08 PM
CivicVoz
Apr 16, 2015 08:07 PM
dano2005
Apr 14, 2015 01:58 AM
