Crank no spark
Old Nov 16, 2013
menusetc's Avatar
menusetc is an unknown quantity at this point
Crank no spark
Working on friends car. Kids replaced distributor, wires....I tested main relay - found bad, replaced - still no spark. 1999 civic ex. No fuel pump noise at all and the check engine light is on during cranking. Im thinking of replacing ecm, unless there is another obvious path. Mechanically inclined......NOT a mechanic and I LOATHE electrical issues. Any, and I mean ANY help would be AWESOME!!!
Old Nov 16, 2013
Re: Crank no spark
Fuel pumps are dang quiet, the relay itself is usually louder.
Ground wires at the thermostat housing broke/loose/corroded/bad connection? That's like the GOD ground for dang near everything related to the computer
All fuses? 13 15 31 (dash)
44 47 (engine comp)
Old Nov 16, 2013
menusetc's Avatar
Re: Crank no spark
Thanks a bunch! Will try tomorrow and see what happens.
Makes me really appreciate old v-8 muscle cars...lol
Old Nov 16, 2013
Re: Crank no spark
Is the new distributor junk?
Does the camshaft turn?
There could be a ton of possibilities.
Old Nov 17, 2013
menusetc's Avatar
Re: Crank no spark
Cam turning, yes. Will test coil tomorrow as well.
Old Nov 17, 2013
menusetc's Avatar
Re: Crank no spark
Happened to be the radio/etc....... fuse in the engine panel. Thanks to all for the help!
martinsmartin
Aug 15, 2015 07:34 PM
Klame9420
Aug 13, 2015 06:00 PM
1khilari
Jul 9, 2015 08:12 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
