A/C valve core replacement
Old Sep 29, 2013
Atarian's Avatar
Atarian is an unknown quantity at this point
First post! I have a 1999 EX, and the A/C Schrader valve on the low side is leaking. Apparently there are about a half-dozen Schrader valve styles, for some reason, which makes the hunt for the correct removal tool all the more 'fun'. I want the type that lets you replace the core without bleeding the system, and I think maybe this one is it: "Mastercool (MSC81490) R-134a Valve Core Remover/Installer"
Amazon.com: Mastercool (MSC81490) R-134a Valve Core Remover/Installer: Home Improvement Amazon.com: Mastercool (MSC81490) R-134a Valve Core Remover/Installer: Home Improvement
Mastercool's website is of limited value as far as application. I could get the 'do everything' kit but I only have Hondas and don't need anything for domestic cars.
Anyone know if this is the right one?
Thanks.
Old Sep 30, 2013
Re: A/C valve core replacement
Can't tell if it's right for your car, you need to find and check out whatever specs it has.
Before you buy anything pricey, I'd say to try a valve core tool that fits any standard car (or bicycle) tire valve core (if it fits), see if your AC Schrader valve simply needs tightened.
That size is likely to fit at least one, if not both, valve cores in your AC.
If not, then one of these probably fits
http://www.denlorstools.com/home/dt1/page_22601_159/milton_industries_s-444_tire_valve_core_tool.html
Both of those are dirt cheap.
Old Sep 30, 2013
Atarian's Avatar
Good idea. I bought the $4 Chinese valve core kit with tool, two caps (one doesn't fit, neither has O-rings) and Schrader valve cores. Leaky core seems tight - I don't want to death torque it though. Just got done.
I went to Rockauto.com and called the local store and both say I have/need "JFA" style valves, although the O'Reilly guy was not completely sure. I'll end up ordering the more expensive valve core kit that does both - maybe it will fit my Accord also, although that's under warranty.
Old Sep 30, 2013
Honestly, I know there are a few different types of the valves, but I have never seen a name or number designation in Hondas literature. We just remove it and match it up from a selection that came from the local parts store.
Honda wants to sell the complete line instead of the valve by itself on many of their cars.
Oh yeah, don't break yours off or you will be in a heap of trouble LOL.
Old Oct 1, 2013
Atarian's Avatar
Breaking it off would definitely suck! I can't believe the o-ring in the cap has held the system together for so long. I recharged it about two months ago and it's still fine. I just can't leave well enough alone, I guess.
Old Oct 1, 2013
That's exactly why a quality cap has the rubber seal in it.
Of course, it has to be tight in order to do its job.
mikemc422
Aug 9, 2018 05:41 PM
usajags84
15
Aug 19, 2015 03:12 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
thesushiboy
Apr 12, 2015 02:54 AM
deception420
Dec 6, 2001 02:31 PM
