stripped axle spline
Old Aug 18, 2013
cheapjoe's Avatar
cheapjoe is an unknown quantity at this point
Please tell me i didnt kill my trans... i just put in a JDM into my 98 civic. this is my DD so i just wanted it to be reliable. the motor install went fine, fired up with no issues. i installed my axles and went around the block for a test drive and to warm it up to set the timing. little did i know i didnt have the passengers axle fully seated and stripped the spline in front of the retaining ring. so now i nave little bits of those teeth in my trans. i have searched but either im looking for this info incorrectly or no other dummy has done this. please help me decide what i need to do. getting a new axle is not an issue, but what do i do about the metal bits... is my trans ruined??
this was my first motor swap and i was so proud when it fired up. now i have made matters worse.... please help
Old Aug 18, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: stripped axle spline
Hmm.. You might be able to blow them out with an airline and then just install a new axle. It's worth a shot.
Old Aug 19, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
you have a 50/50 chance of ruining your trans. Honda trans have a magnet on the inside to help catch shavings and such, but prolly won't catch them right away, so you take the chance of your gears catching them. I would drain the trans and see how much comes out and re-fill it or flush it with some cheap-o oil first. If you don't get much out, your going to have to slit the case and get the rest out.
If it were me, I would pull the trans and split it anyways and clean it out. You should only need some new oil and some Honda-bond to re-seal it. It's not hard to just pop it apart, clean it out and put it back together.
Did you get another d-series, or did you go b-series.? I have a write up on pulling apart a b-series trans, should be the same concept for d series, if it'll help.
2002ExCivic
22
Sep 28, 2015 08:29 AM
beanhead
Sep 24, 2015 12:04 PM
bashea
Sep 15, 2015 04:59 AM
WaryDriver
Aug 8, 2015 05:08 PM
califcamper
Jul 21, 2015 10:34 PM
