oil breather chamber
Old Aug 13, 2013
oceanbreeze's Avatar
oceanbreeze is an unknown quantity at this point
96 Civic Ex, auto, D16Y8 engine
I am trying to remove the oil breather chamber and clean it.
Anyone know how I can remove it? I removed the two 10mm bolts and the nut for the wiring harness bolted to it, and it now rotates but pulling it does not work. If I were to guess, either it is gunked up way too much inside or there is a hidden bolt somewhere?
Does it just have a tube with an o-ring that sticks into the block? I am not into using a lot of force.
Thanks for any help.
EDIT: diagram here: http://www.hondaautomotiveparts.com/...HAMBER+%282%29
Old Aug 19, 2013
Poopies's Avatar
Super Moderator
Re: oil breather chamber
Taking a picture of the thing could help us.
Old Aug 23, 2013
I couldn't get a pic of it. it's part no 1 in the diagram on the link I posted above.
did you ever take your's out, and if so, did you have any difficulty?
Old Aug 23, 2013
Poopies's Avatar
Super Moderator
My car is 7 years newer, so it's a bit different. I've heard of taking the PCV (positive crankcase ventilation, part 3 on the diagram) valve out for cleaning but never the chamber itself. According to that diagram it should just be those 2 bolts you mentioned, plus the PCV breather tube. It looks like the whole thing might screw in... have you tried turning the whole assembly a bunch of times and seeing if it gets loose?
emich
Dec 11, 2015 12:20 PM
carid
Nov 7, 2015 01:46 AM
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
