Oxygen Sensor Dying?
Old May 20, 2013
spyglass's Avatar
spyglass is an unknown quantity at this point
98 Honda Civic DX. The codes were accidentally cleared, but I am getting stumbles at acceleration at low speeds. It seems to be get worse with hot weather. Is this an indicator that the oxygen sensor is failing? If so, which one? I am thinking it's the one in the engine, which I believe is called the upstream oxygen sensor? Thank you.
Old May 20, 2013
Re: Oxygen Sensor Dying?
If you think the O2 sensor is causing it to stumble, then simply unplug it. (You are right about the upstream sensor there.)
See if it still stumbles. I bet it still does.
If it still does, then keep checking elsewhere. Ignition is the usual cause of a load related misfire. Cap/rotor, wires and plugs.....and the plug holes full of oil on many of the engines.
Old May 20, 2013
spyglass's Avatar
It did turn out to be a distributor issue. Your advice right was on target. Thank you. I think the key was it did not throw a new CEL code after the old one was cleared.
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
ZILLA
Jul 5, 2015 05:24 PM
