1999 Acura CL 1259 Code
Old Sep 25, 2012
GVargas40's Avatar
GVargas40 is an unknown quantity at this point
Cool 1999 Acura CL 1259 Code
I have a 1999 2.3L Acura CL, my daughter blew out the head gasket and ruined the head and the block. I found another motor off a 2000 Honda Accord, the motor was an exact replacement. I just had to swap out the Inake manifold and the exhaust manifold. All the wiring was hooked back up to the normal connections, I even took the old VTEC selenoid housing off the old motor and put it on the replacement motor. The screen was clean and fresh oil was put into the replacement motor. I turn the ignition on for about 7 minutes before I started the car, the car started right away with no problem. The car runs great, no hesistation, no misfiring, no RPM problem, nothing at all. But the CEL came on, got my code reader and it came up with the P1259 code. Any suggestions from anyone!
Old Sep 25, 2012
Re: 1999 Acura CL 1259 Code
Check this answer:
https://www.civicforums.com/forums/3...ml#post4618312
Jul 12, 2015 11:54 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
Bounddyy
Jul 8, 2015 11:22 AM
cgavin1
Jul 7, 2015 07:10 AM
