Transmission slips when hot
Old Jul 2, 2012
Timt's Avatar
Timt is an unknown quantity at this point
I have a 96 Civic that will not shift into low at stop once it has warmed up. If you pull the shifter down it pulls off fine, but if you leave it in drives it shutters and slips. Once you are rolling all the other gears shift fine. When you first get in it, it will pull off but shifts hard but does it on it own.
I ran a wire to the solenoid to where I can put 12 vots on it and it will shift and pull off fine. I checked the voltages on the TPS and they are good. I am not sure what is sending the signal to the solenoid to tell it to make. I tried a different PCM and have swapped the transmission, it still has the same problem.
Any ideas?
Old Jul 14, 2012
nightmarecivic's Avatar
nightmarecivic is an unknown quantity at this point
Re: Transmission slips when hot
Suffer and enjoy it.
Jul 12, 2015 11:54 AM
ZILLA
Jul 10, 2015 06:05 AM
CivicsClass101
Jul 9, 2015 11:14 AM
