1998 Civic stalled now no start
Old Dec 17, 2011
ol55's Avatar
ol55 is an unknown quantity at this point
Was running fine. Now no spark. Replaced distributor cap and rotor and checked plugs. Engine cranks and can hear the fuel pump. Dwell is between 11 and 14 (so ok to assume the coil is ok) Is the black rectangle in the distributor the module? Is it removable? Where to from here?
Thanks Larry
Old Dec 18, 2011
ol55's Avatar
Re: 1998 Civic stalled now no start
we replaced the distributor with a pick a part one and it seems to run fine. Is there a fix to make the old distributor functional again?
Thanks,
Larry
Old Dec 18, 2011
Wrong assumption.
A dwell reading (checked at the coil) means that everything before the coil is working. It is trying to fire the coil.
You have a dwell reading when the system TRIES to fire the coil.
If there is no spark from the secondary tower of the coil, the coil has to be bad.
Sounds like all it needed was a coil, not a complete distributor.
BTW, I see about 2-4 degrees dwell during cranking most of the time. (Meter set to 4 cylinder scale).
If there was no dwell reading at all when measured at the coil (cranking the engine), then the igniter isn't trying to fire it. More testing needed.
Old Dec 19, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
https://www.civicforums.com/forums/1...ont-start.html
McD
Apr 29, 2015 03:50 PM
Richkid23
Apr 19, 2015 12:53 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Hrddrvs
Apr 11, 2015 11:22 PM
