Heater only blows through one vent?
Old Dec 6, 2011
yansold's Avatar
Yuh
yansold is an unknown quantity at this point
I have a 1998 civic dx. Its gotten cold and in the morning when I start it up and get the heater going it fogs up. I tried to turn on the defroster but nothing comes out. my rear defroster works fine. I realized the heater and air conditioner work fine on all levels just it only goes through the chest vent (ones on dash).
when i switch to the other one it makes no noise and the light comes on like it changed but still only comes out from chest vents.
Does anyone know how to fix this problem? or has anyone had this problem?
Old Dec 6, 2011
yansold's Avatar
Yuh
Re: Heater only blows through one vent?
I have also noticed when ever I click the defroster button the a/c turns on. but stays off when I press any other buttons.
Old Dec 6, 2011
MelJ's Avatar
Trance Addict
The a/c kicks on in defrost mode to dehumidify the air. Most cars do that by default. Have you ensured all your connections are fine in the climate control switch?
Old Dec 6, 2011
yansold's Avatar
Yuh
Well I have not taken the climate control out yet. but have done some researching and found the switch/gear type thing that when heater is turned on if you try and move it you can tell that the air is starting to come from the floor vents. I have noticed when you press the button it doesn't move the switch/gear thing at all. which I am pretty sure it is suppose to? Ill post picture.
Old Dec 6, 2011
MelJ's Avatar
Trance Addict
Yeah. It's suppose to move. I know I had an issue with my switch, but it dealt with the fan not working on higher speeds. Have you made sure everything is still on there? I know the blend door arm for the Accords had an issue where the wire would come off and you had to use a piece of vacuum line to keep it on. Different issue, but sometimes the smallest things cause the biggest headaches.
Old Dec 6, 2011
yansold's Avatar
Yuh
It seems to me as if everything is still conected, atleast from what I can see. I guess ill have to take the climate control panel out. but wont be able to do that until the weekend since I have school during the week. But if you notice that bar on the right side in the picture its attached to that black thing which seems to be a solenoid or moter type thing of some sort. not quite sure what it is. but could that maybe be my problem? do the 98 civics have that type of workings in them?
Old Dec 11, 2011
yansold's Avatar
Yuh
Can anyone update me on this? Still havnt found a fix to this problem. Are there solenoids to move that white piece?
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 3, 2015 04:33 PM
senicalj4579
Oct 2, 2015 10:03 AM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
