power window failure
Old Sep 23, 2011
m reed's Avatar
m reed is an unknown quantity at this point
Hey, My drivers side window isn't seated in the groove properly when the window is raised. Today, it made a loud grinding noise when raised. I was able to help the window up by hand.
Is this a failed power window motor?
Old Sep 23, 2011
lazlong's Avatar
Re: power window failure
If it's the motor it would struggle to raise and lower, not pop out of the groove. More than likely the the bearings in the regulator (window track) have gone bad. Pull the inner door panel and look and see if it's popping out of the track. Replace the regulator if it is.
Old Sep 23, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
I'd replace the motor while you're down there. If you're gonna go through all that trouble over a regulator might as well swap the motor since those tend to fail (I've had to replace two of mine). On the plus side the regulators usually sell with the motors (that's how I bought mine) costs about $50 and an hour and a half per door for labor.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
