wont start
Old Aug 28, 2011
tarp's Avatar
tarp is an unknown quantity at this point
wont start
checked about everything.
What i found is that upper pulley for timing belt is turning, however the cam is not. Any ideas on problem?
Old Aug 28, 2011
MelJ's Avatar
Trance Addict
Re: wont start
Were there any stored codes, did you get a CEL? You may be looking at a position sensor issue. I'm guessing the pulley is moving when you try to start it?
Old Aug 28, 2011
tarp's Avatar
Re: wont start
It sheared key in timing belt pully on camshaft. Why would camshaft lock up?
Old Aug 29, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: wont start
if the cam is locked up it could be bent valves or a warped cam which i highly doubt it
Old Aug 29, 2011
MindBomber's Avatar
Live for the Twisties
Re: wont start
+1... bent valves.
Old Aug 29, 2011
tarp's Avatar
Question Re: wont start
Had to use pipe wrench in order to turn cam. All the valves are moving, however it does get real hard to turn in a spot or two.
The oil light came on just a few miles before it stopped running.
Any ideas on the possible cause? Also what all do i need to check/replace? Any help appreciated.
Old Aug 29, 2011
turbo_coupe_EJ1
Re: wont start
well it doesnt sound good when your oil light came on and it quit running but anyways i would take the head off and take it to a machine shop and see if it needs worked annd i would also check the block and pistons
Old Aug 29, 2011
tarp's Avatar
Re: wont start
doing it now.
do you think i need to replace oil pump?
Old Aug 30, 2011
turbo_coupe_EJ1
Re: wont start
was it low of oil when the light comes on
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
