Overheating
Old Aug 22, 2011
HondaChick83's Avatar
HondaChick83 is an unknown quantity at this point
Overheating
My 2000 LX has been overheating for a few years now. I had my timing belt and water pump changed but it was still doing it. I had the thermostat and sensors changed and it still did it!
We decided to rig the radiator fan to run at all times. Stupidly, we used the fan relay slot for a power source and it popped the fuse under the dash and the A/C and radiator fan stopped working.
What's a better power source for the fan?
Old Aug 22, 2011
Re: Overheating
running the fan will not fix overheating. the fan is only useful when the car is at idle to drop the temp a few degrees when the engine is running normally. there are many things it could be but start with a honda thermostat and radiator cap. then go from there. could be a clog in the cooling system, heater core, or air in the system.
Old Aug 23, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: Overheating
does it use or lose water
Old Aug 27, 2011
Re: Overheating
Now that doesn't answer the question, does it, boys?
I need that power source, stat.
Old Aug 27, 2011
MelJ's Avatar
Trance Addict
Re: Overheating
Demanding an answer will get you nowhere. Gearbox gave you a great place to start which is the most cost effective. And turbo asked a very valid question. Techs have to go through the same troubleshooting and even if you were to bring it to a shop, you'd still go through the same process. It could be a bad radiator, bad cap, basically all the stuff said earlier. There's just too much it can be as these symptoms can be caused by a number of things. As for the power source, you're just putting a bandage over the problem and not fixing anything.
Old Aug 27, 2011
turbo_coupe_EJ1
Re: Overheating
the reason i asked was because if it was losing or using water it could be a leaking radiator (like melj said) or a head gasket or a clogged radiator
Old Aug 29, 2011
vwjimmy's Avatar
2000 Civic Coupe
vwjimmy is an unknown quantity at this point
Re: Overheating
You can jump the fan in the relay socket...you just picked the wrong power supply line. It is not going to solve your problem though......
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
tooly145
Sep 5, 2015 01:05 AM
