d16y8 engine
Old Aug 8, 2011
aaron187's Avatar
aaron187 is an unknown quantity at this point
d16y8 engine
Hey ya'll. I just bought a 98 civic ex with the vtec, manual tranny. It was ran with no oil and it needs to be replaced or rebuilt. I've rebuilt engines before but not one that has been ran with no oil, so (dont bother offering swaps), question is,
which year model engines will fit?
does an engine from an automatic need to be tuned to a manual? will it plug into cpu?
could i take a d16y7 short block and mount the y8 head on it?
will an older 1.6 (OBD1) work in this OBD2?
please help on these issues. and if anybody has one for sale, let me know.
THANKS!
Old Aug 9, 2011
aaron187's Avatar
Re: d16y8 engine
Come on Ya'll give me some ideas
Old Aug 10, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: d16y8 engine
the d16z6 would work but you have to get obd1 computer and harness but you could rebuild that motor , if you did you would have to get the block bored or sleeved (the machine shop would let you know how much it would need to be bored) , then i would have the head reworked also , and if it has a hole in the block you could just forget about it
Old Aug 10, 2011
aaron187's Avatar
Re: d16y8 engine
i was told that the z6 would fit int here but I wouldn't have a crank sensor. but as far as an engine that has been paired with an auto or manual tranny, would they have different bell houseings?
Old Aug 10, 2011
mike98's Avatar
mike98 is an unknown quantity at this point
Re: d16y8 engine
I know for sure that you can use any 1996-2000 d16 engine block.
The y8, y7 are the heads and yes, they can be swapped.
You can use a d16y8 from an automatic with no problems as long as you don't use the auto intake manifold. Reason for that is that the manual has different iacv from the automatic.
Of and don't forget to use the manual flywheel (including the longer bolts that it comes with) and not the automatic one.
Old Aug 10, 2011
aaron187's Avatar
Re: d16y8 engine
Mike thanks a million. now i can get to finding something
Old Aug 14, 2011
aaron187's Avatar
Re: d16y8 engine
change your oil kids
Old Aug 16, 2011
Stock 99's Avatar
Re: d16y8 engine
OMG!
Talk about a picture being worth a thousand words.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Supramk3
May 11, 2015 07:55 PM
bluecoupe
Jan 23, 2002 05:50 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
